Hi I recently got a boat with a 75hp mercury outboard on the back. Was told it has a slight miss and needed to sort it out.
I have done compression test and all were 142-151psi.
have done a spark test and here is what I found.
Only cylinder number 1 was sparking. I tested each plug and lead and all sparked when plugged on coil number 1...
then randomly i got spark on 1 and 2...
I thought it was the coils so Pulled them off and rearranged the order. I tried the bad coils in the good coils position and the coils sparked so the problem is before the coils
what's the most likely problem? The stator, trigger or power pack? And how do I check which one is faulty? Dva and Resistance check the trigger and the stator but How do I test the power pack?
