86 larson citation 175 mercruiser 170470
dee_c
"I would like to replace my me
"I would like to replace my merc 170/470 with another motor. Does anyone know what engine might work instead? ( Motor Mounts, horsepower equivelent, etc. )"
"Dave.
Post a bit more info,
"Dave.
Post a bit more info, do you want to go bigger ?
What are you looking to achieve ?
What model Out Drive is on the back of it ?
Do you know your final drive ratio is ?
Bear in mind anything is possible and is generally only limited by the size of your wallet.
Cheers
Peter C"
"Thanks Peter, I am trying to
"Thanks Peter, I am trying to replace the 470 with a comparable engine of horsepower. I have had lots of problems with the 470. Overheating, water in the oil, ( head gasket replacement and other trouble shooting methods have not worked ) looks alot like it could be a cracked block, voltage regulator issues. It has the alpha one sterndrive but I don't know the final drive ratio. I have decided to stop the bleeding from shop bills and just replace it. Thanks"
"Dave:
Before spending a
"Dave:
Before spending a dime more, check the transom, stringers and floor for rot--very expensive repair unless done by you.
If you want to get away from the 470 it is going to require a complete Merc. drop-in engine. I am assuming that your boat is 17.5' in length. A 4.3L w/4 bbl carb will produce 190+ hp for about $4,000. That's alot of punch. Engine mounts will need modification. OD gearing may need changed to handle it--not sure.
Maybe you should consider a reman. longblock 470 with an external alternator kit. Probably half the cost."
"Dave
Sounds like you had a
"Dave
Sounds like you had a dud.
Guys advice is very sound, but if are not replacing apples with apples it will get costly.
I would seriously consider the remanufactured 470 longblock.
Have a close at your manifold and riser if you have had water in your old engine
(how did it get there)
cheers
Peter C"
"Dave;
You should check with
"Dave;
You should check with your boat manufacturer and see what optional engine packages are/were offered, This will give you a good idea what you can do that will fit.
You could drop in a 220 hp 4.3 V-6 for instance. The length will be OK, but you need to check the width dimension. Also the 4.3 will be heavier. The 4.3 is a good solid reliable engine and should treat you well.
Your drive is likely a 1.94/1.91 ratio. The 4.3 uses a 1.81 ratio normally, but you can likely make yours work with a prop with more pitch.
Rod"
"Peter, Guy and Rod this is th
"Peter, Guy and Rod this is the first time I have ever used a message board for any thing. And thanks to you three its has been a very good experience. I value all of your insight and advise. I'll probably look for a remanufactured long block to keep cost down. Thanks again Dave"
