"I just bought a 5.7 mecruiser
"I just bought a 5.7 mecruiser alpha 1. I'm not sure the boat was winterized.It will not start.
I replaced the starter, same problem. I talked with a couple different mechanics about it. And was told to eliminate some possibilities.
I took the drive off,pulled the distibutor and primed the oil pump for 15 min, put back on.
took the plugs out and sprayed penitrating oil in the combustion chambers.With plugs still out I cranked it over and got about 10-15 revolutions
in 4-5 seconds then smoke starts coming off the pos+ battery terminal. I put the plugs back in and only get about 4-5 revolutions in 4-5 seconds.Again with the smoke. The engine is groggy as hell.And that poor starter has a tuff time turning it over. What can I do? Is the engine shot. Could there be a way to get this groggy engine spinning again?
Any help will be greatly appreciated.
thanks."
thanks."
