RicS1953
Hi all,
I removed and disassembled the lower unit to replace the seal set and to inspect parts for wear, also replacing the water pump's impeller, key & water tube grommet.
I reinstalled the lower unit today and it seems now I'm having difficulty with the shifting.
It's currently in forward gear and can't shift to neutral or reverse.
Does anyone who's done this work before know what the problem(s)
might be? I'm sure that the shift lever, yoke, and cradle are correctly in place
along with the phillips screw that retains the shift lever in place. Any ideas?
The model of my Evinrude is an E25ECDR.
