I am sure I will get a nice lecture over this one. I recently aquired a 16ft Charger with a nice trailer and a 90 HP Mariner. The boat has sat outside, near the lake, possibly sometimes partially in the water since 2003. I retrieved the boat and got it home. The power trim works perfectly but the motor is seized up. When I pulled the plugs they are ALL rusty. I tried spraying wd-40 into the spark plug holes. It is frozen solid. My neighbor and I used a breaker bar on the fly wheel nut....gently....but with enough umph to break it loose if it were going to be that easy. I have read all kinds of ideas and the main consensus I see is that the motor is toast even if I were able to get it freed up. I would appreciate any advice or possibly even confirmation to scrap it or keep trying. We are both mechanically inclined, the neighbor more-so than I, but neither of us have alot of experience with a 2-stroke outboard. When I got this boat the guy also had an 80's model Sylvan pontoon with a 28 hp Evinrude. The difference I think is that the Evinrude was not trimmed up. I put fuel and power to it and had it running within 10 minutes. Not so fortunate with the Mariner. From the looks of the boat the rear has been partially submerged at one time or another from the way it was sitting on the shore. I am guessing that water has sat in the motor.....unfortunately. Thank you very much for any thoughts, opinions and ideas.
John
John
