"Hey guys. I have an 86 350 m
"Hey guys. I have an 86 350 merc. That has been giving me idle problems. I had a manifold choke q-jet carb on it that gave me hell for the past few years. It would load up with fuel and kill the motor then to start the boat back up took forever because it was flooded. Last week I purchased a newer electric choke q-jet carb and installed it. This fixed my starting problem however, the boat still won’t idle below 1000 rpm but runs great at high rpm. The set screws don’t do anything they can be all the way in or out and it doesn’t make a difference. The gasket for the carb is new. We tried spraying carb cleaner all around the intake and that didn’t do anything. We busted out the timing light and the timing would be at 8 degrees, flicker down to 0, go back to 8, flicker down to 0 and then the motor would die. We changed out the thunderbolt IV, checked the voltage off the coil (14V), and checked the sensor in the distributor cap. Nothing has helped. Today we were going to check the valves and make sure they are not too tight and check the ground off the distributor sensor. The compression is consistent in all cylinders. The vacuum is 10psi at 1000 rpm and 15 psi at 2000rpm (seems low to me). If I place my hand over the top of the carb it runs way better so I am thinking a vacuum leak. However, the flickering of the timing has us scratching our heads. If nothing works out today I think my next step is to replace the intake gasket (even though I don’t think its leaking)…… thoughts, questions, comments, and suggestions are all welcome.
Thanks, Mike"
Thanks, Mike"
