kippstakes
So I think I might have gummed up the timing on my motor, or maybe the idle throttle- I don't know.
Three days ago she started up without any trouble, and ran like a top. Compression is perfect, solid spark on all four.
What happened was I was having trouble getting the throttle up to wide open- the control lever seemed to bottom out around 1/3 throttle. I tried compensating by adjusting the throttle at the throttle cam (which I now realize was a mistake). Turns out, after splitting the control box, my throttle cable was just binding. Luckily I had a replacement on hand, which fixed the binding problem once installed.
HOWEVER, when I went to start her up today, it would only occasionally sputter a bit and then die, and barely that. I must have screwed something up with the timing or the start position on the cam.
Update: I adjusted the cam plate so that there's a hair of space bt it and the throttle roller. After some cranking, lots, she finally and grudgingly started up. It seems to run a little rough now tho, or maybe I'm just being overcautious.
Any ideas??
Here's a vid for reference.
https://www.youtube.com/watch?v=XIQa...dIfwUA&index=1
Thanks!
Any ideas??
Thanks!
