I am working on a 1989 Force 85 hp. the lowest cylinder is not making power. I have checked the carbs, seemed clean but still blew out all the passages after removing the jets and air bleed. All 3 cylinders have 120psi compression, the spark will jump about 1/2" but it doesnt seem to me as crisp or full as the other 2 cylinders. Is it possible the coil is bad and canno jump the gap while under cylinder pressure? An assistance would be appreciated.
thanks
thanks
