85 omc outboard cutting out
B
Brian Zieler
Guest
"I have a 1985 omc 2.5 litre s
"I have a 1985 omc 2.5 litre s-type outboard. It is a v6. I will be riding smooth at 3100 rpm and then the enigine will just cut off. Sometimes if you get it into neutral fast enough you can save the idle. Otherwise you have to restart the engine. Seems to run at 1500 rpm without cutting out, but sometimes it will sputter. Please help me"
chaned out the anti-siphon val
chaned out the anti-siphon valve on the pick up from the tank. Seems to have fixed the problem. Now the primer bulb gets hard too. Thanx
