I had to seal a warped fuel bowl to the carb and gas no longer leaks out. However I can no longer start the engine. It seems like excessive gas come out the fixed carb needle. Now and then the engine will start but dies within seconds. Gas spills out of the needle. If I wait 15 minutes or so it will start briefly again and die. While turning the engine over gas squirts out of the needle.
When I had the fuel bowl apart the float moved freely so I figured it was okay. Could this be the problem? If it is, parts are no longer available including a new fuel bowl and gaskets.
I also noticed the grass underneath the prop was black with oily water. Or could this be carbon? Thanks in advance for any diagnosis.
