1976. Johnson 85
this thing has been sitting for 3 years. So here's what I did. Cleaned the carbs , flushed the fuel system replaced the plugs, set the wot timing after replacing the number 1 coil, which had cracked and was open. Started it up it had a bad miss at idle after a frustrating electrical search I found the red wire on the regulator was broke, so I replaced it. Still had a miss. Backed it into the water so I could make adjustments with a load. Fired right up with no miss, after a thorough warm up I backed out and went around the lake, ran like a dream super smooth and very strong ran for about 15 minutes. Idled into the dock, wife wanted to go so I went to back up put it in reverse it died. It would restart but would not take throttle, idle was very inconsistent. Pull it back to the house fired it up again and started pulling plug wires 1 and 2 made no change 3 and 4 and the engine died. Ran a compression check. 132 lbs all four cylinders. Next I examined the reeds all perfect. So I have spark, I have compression, fuel system is clean, reeds are intact. My thought is that since1 and 2 are the issue, could it be the top carb? By the way, charge is 13.89 at idle with new regulator. Anybody have any experience with anything like this.
