dsharretts
New to me outboard - had water out tell tale one day and zero water at tell tale the next. Didn't know when water pump had been changed so I replaced the water pump - impeller was still intact and didn't look too bad (all arms intact with nothing missing).
Sprayed hose up the water line and had water at tell tale - back flushed water through tell tale hose (using small nozzle on hose) and had water coming out water line. Ran muffs on lower unit while out and had water getting to impeller (intake screens are clean) although no water coming through impeller housing with just water pressure from hose.
Used air compressor to blow back through tell tale hose and can hear air come out water line.
Re-installed lower unit and still no water at tell tale.
I'm working under the assumption that since I had no water with old water pump and no water with new water pump that, obviously, something else is going on. But with the water path apparently not being blocked (water from hose seems to get through) - where do I go next? I've pulled the lower unit and checked the impeller installation 4 times now.
The last time I pulled the lower unit I hooked the muffs to it and turned the drive shaft by hand and it pushed water out of the impeller housing - so I'm confident that the pump is functioning.
I removed the tell tale plug from the engine block and ran the engine again - no water making it to the engine. I'm assuming by looking at the Johnson V6 water flow diagram that the tell tale is connected right away when the water enters the engine from the water tube.
So If I have no water there, does that mean that my water tube is messed up? Keep in mind that I had no water at my tell tale before I ever replaced the pump or removed the lower unit. I just started with the pump because I figured that was the most obvious issue.
Any assistance is GREATLY appreciated. Thanks.
