bandbautowurks
"I recently aquired a 85 hp fo
"I recently aquired a 85 hp force motor. Some of the harness wiring was damaged by what appears to be a mouse. I know it needs a water pump, and a good carb cleaning. The olny problem is that the model # is not coming up on the site I usually use to find this stuff. It is the black/charcoal color, with the blue prestolite ignition system and had 3 cylinders w/ 3 carbs. On the tag at the base of the pivot clamp it says: X858F9F for the model and the serial # is X18605. Any help would be appreciated."
