"I've looked for the answe
"I've looked for the answer to this question for a while but could'nt find a specific answer, so for all you Force outboard veterans out there, bear with me if this is a repeat quistion...
I have two related cooling questions about my 85 Force 125...
First deals with cooling water exit location. Please tell me if I understand this correctly: While running the motor in a bucket/barrel or with the hose attachment hooked up a small but steady amount of water spits and spurts out of the two holes located on the back of the leg above the water line. There is also a large amount of water steadily running out of the exhaust port above the prop. I understand this to be normal for Force engines and this is what I should expect since there is no formal "telltale" factory installed on these engines. Is this right, or should there be a steady squirt "shooting" out of the two small holes on the back of the leg???
Second, while looking to an answer to that question, I read some references to flushing and "back flushing" the cooling system. I have the SELOC manual and have read backwards and forwards, and can find no reference to flushing or backflushing the cooling system. Can someone line out the procedure for me, and tell what I should be looking for while doing this, or at least direct me to where I can find the information??
Thanks in advance for your help..."
