Hi everyone, first post here.
I was left an '85 Evinrude 30 (E30TELCOA) by my uncle who passed away. The motor has sat completely unused for at least 10 years. I have decided to put the motor to use this summer for my son to putt around with. When I went to assess the condition of the motor, I found that the gear selector lever (this is a tiller steering model) was stuck in forward, and I can not get it to shift to neutral. Any ideas on what may be causing this?
Also, as the motor was sitting unused for so long, what maintenance should I perform or parts should I replace before I try and start it? I'm already figuring on an impeller for the water pump and a possibly a carb cleaning, but are there other service you guys would recommend?
A little info about the motor: It has low hours, and my uncle was a fanatic about storing his outboards properly. It appears that the carb was starved on shut down (fuel line removed), and everything was sprayed with corrosion inhibitor. The motor was used in salt water, however it had been thoroughly flushed after every use.
Thank you for your help!
Rob
Rob
