84' Quicksilver 470 Mercruiser
olwebb84
hello all, I'm currently remodeling a 1984 Webbcraft with a 470 Mercruiser that is using a quicksilver throttle. The side panels are rotted out and I'd like to reupholster them, but I can't seem to figure out how to get the throttle off. Anyone worked with these before and have some pointers?
TIA!
Put throttle lever in 12:00 position.
At bottom of lever there is a hole.
Use a 5/32" allen wrench to loosen 1/4-20 set screw.
Once loose enough handle will pull away.
You also beed to remove lever cover (where square trailer button is) and disconnect wires ( pin, socket).
