84 OMC 57 Stearn drive seal change
salt_fever
"While fishing I noticed an oi
"While fishing I noticed an oil film in the water after anchoring. I immediately went back to the ramp and pulled the boat out. When I took the drain plug out there was about 4 - 5 gallons oily water that ran out. When I got home and parked the boat I noticed oil dripping from the steering gear. Is it possible that the seal around the steering gear could let that much water in the bilge or do I have a seal cracked around the transom? My bilge pump is new and works.
Since I need to replace the seal around the steering gear I plan on replacing all of the seals in the upper, intermediate and lower unit at the same time. Do I need any special tools to replace all of the seals and how difficult is this task? Should I take it to a mechanic to replace the seals?"
the steering gear is on the ou
the steering gear is on the outdrive out in the lake. Any oil that leaks out of there would not be end up in your bilge.
I think your engine is leaking oil.
