84 Mercury Outboat Fuel Pump
tommy4132
I just picked up this motor and I have limited knowledge of outboard motors. One of my lines on the fuel pump is not connected to anything. Does anyone know where it might go?
Two lines are for dopey water cooling of the FP, one is fuel inlet, and one (that should have that filter) the outlet.
Jeff
PS: If that's a triple, you want to plug the water line going to the FP to prevent cooking the top cylinder.
Thanks for your help, the two water cooling lines were throwing me off and previous owner removed original fuel filter set up. THe line that is not connected is just a fuel line then. Haven't started the motor yet, have a frozen choke soleniod and trying to make sure everything else is hooked up correctly.
