My engine has a slight miss, predominatly at low speeds (1500 - 2000 rpm). It seems to go away at higher speeds. In the past, I have corrected this with a tune up (new points/plugs). The points still look good but it has been a couple years since I replaced them.
I would like to do a complete tune up before winter storage. Timing has always been a mystery on this engine. The shop manual says to plug the vacuum advance before timing. I don't see any vacuum advance. Is there suppose to be one? Should I time it to the spec and ignore manual's instructions regarding vacuum advance? If not what should I do? Also, will any timing light work OK? The manual says something about using a certain light (I don't have the manual in front of me right now). Any other tips on timing or tuneup? One last thing, can I convert this distributor to an electronic igntion? It has very low hours and I'd like to keep it for a while.
Greg
Greg
