Got it all put together and it runs great. The problem is the recoil. I made it nice and tight on the spring and I believe it is put together correctly but I pull to start it and the cord often stays out about 3 ft. Gentle pulling seldom makes it retract. I had to remove the cover and gently help it retract. The little cut out on the cup where the outside bulge in the spring sits is a bit damaged and that is the only thing I see wrong with the assembly. Would it be as simple as just replacing the original spring? A thinner cord? It seems like there is plenty of retraction power but it gets stuck in the out position.
