84 Evinrude E60ELCRE low compression in lower cylinder
bcsix
I have 150 lbs of compression in upper cylinder, and only about 70 in lower cylinder. Is there something other than a bad cylinder that could be the cause, what should I look for first? Never lost water flow.
Pull the cylinder head off.-----If you are lucky it is a blown head gasket.----Very common for those high revving motors to break piston rings.----That would be an expensive repair if you need to hire a shop for that work.
Thanks, I'll pull the head off and maybe I'll get lucky
