goat roper
I started out with no fire except cylinder #4. Using the specs, an ohm meter and a DVI adapter, I found the stator, trigger and coils all tested within specs. Next, I moved the primary side wires from coil #4 to each of the other three coils, one at a time, and got fire in each one, firing the plug for that cylinder. Unable to find a way to test the switch box, I have to conclude that through trial and error, the switch box is faulty. Do you agree or is my thinking flawed? Also, are there any opinions as to the reliability of the Sierra after market switch box?
