83 rude stator problems
cruisecontrol49
"I recently purchased a 83 rud
"I recently purchased a 83 rude 140hp v4. This motor appears to be a very clean, low hour motor. The motor runs fine wot, but has a very rough idle/low speed.
I noticed drippings underneath the flywheel and the flywheel becomes as hot as the top of the block after a 20 minute run. The block and the flywheel are so hot you cannot hold your hand on them. The motor is peeing strong. I don't remember a flywheel getting that hot on my other motors.
Do you guys think it's just a bad stator causing the hot wheel and the rough low speeds?
I have checked compression and it is good. I am waiting to see what you guys think about the stator before I get into the carbs, spark, link & sync, etc.
thanks again guys for your time and your knowledge.
Bruce"
"Bruce,
If the drippings lo
"Bruce,
If the drippings look like melted plastic, you should pull the flywheel and have a look. It should not get as hot as you have noticed.
Tony"
thanks for replying Tony!
The rough idle problem turned out to be a sheared key and a sync problem.
I learned a very important lesson. NEVER PUT ANTI-SEIZE ON A CRANKSHAFT/FLYWHEEL ASSEMBLY. The mechanic told me the extra lube interferes with the pressure fit and causes the flywheel to shear the key. He was right!
I am still going to replace the stator.
thanks again for your reply and your time.
Bruce
