83 mercruiser 120
emac
Hi there, helping my brother with this boat he just got, 83 larson w a 120 mercruiser 4 cylinder, rochester 2bbl carb. Whats been done so far: new starter, new plugs, new plug wires. gas lines replaced. It will start right up, but stalls immediately when put into reverse, forward seems to be fine. now on side of hte engine, what I think is the neutral saftey switch was very loose, tightened that down, and the it doesnt really seem like the electric choke is doing anything, shouldn/t it close the flapper when starting? Just ordered the manual, short term plan is to rebuild the carb now and have the timing checked.
Mercruiser uses a shift interuptor switch, Look at where the shift cable from the control box ends up back at the engine. There will be another cable there also. The short shift cable. This cable goes thru the transom and it what shifts the outdrive.
When the engine is running and you are in gear either forward or reverse, when you try to go back to neutral the cyntrifical forces on the gears wont let them seperate. Thus the interuptor switch. There is a large plastic V notch that moves when resistance is present on the SHORT SHIFT CABLE only.
this V notch moves and activates the switch causing the coil to be shorted to ground, thus shorting the ignition to ground.
This is only susposed to occur for a split second and as soon as the gears seperate the V notch reurnes to its centered location.
When the short cable get old, too hot or is kinked or possiby the linkage in the bell housing or drive is not moving freely this will cause the V notch to activate stalling the engine. Also if the cable is adjusted improperly this will cause the same condition and should be checked first.
read below for shift cable instructions.
Trim out drive up 2 inches from all the way down.
Take keys out of ignition!!!!!!!!!!!
Have a second person stand at the prop.
You, remove the short shift cable from the shift bracket. The cable should move in and out with only two fingers of effort. If it is difficult the the cable must be replaced!!
If the cable moves freely and easily then:
After the cable has been removed, push the plastic cable end all the way in and hold in place while prop is being spun C’Clockwise..
Have second person rotate prop counter clock wise until the prop is fully engaged and wont turn anymore. Maintain light effort on shift cable plastic end pushing it to keep forward engaged.
Measure the distance from the center of the brass trunion to the center of the round mounting hole in the plastic end. Adjust trunion to make that distance 6 inches. no more no less! In cases where the shift cable is old but still works well you can adjust this dimension to 5 15/16”. NO MORE.
Put shift control handle in forward FULL throttle position.
Remove the control shift cable from shift bracket at this time.
Install short shift cable back onto bracket at this time.
Take the shift control cable and adjust the trunion so it fits perfectly back into the shift bracket.
Before installing it turn the brass trunion 4 complete turns away from the plastic end and reinstall into shift bracket.
Now put shift control handle in the neutral position.
Have second person spin prop, it should spin freely.
Put shift control into the forward detent position at ~ 10:00 position. NO FUTHER.
Have the second person rotate the prop counter clockwise. You should have solid engagement with no ability to continue to turn the prop.
Now shift back into neutral. Prop should spin freely with no clacking or clunking.
Now shift to reverse to the 2:00 o’clock position detent NO FURTHER!!
Have the second person spin the prop clockwise.
If you have positive engagement with no clunking or jumping out of engagement, you are done.
If it does not fully engage into reverse than look at the shift bracket where the short shift cable mounts and there is a slot. Loosen the 7/16 hex that is touching the bracket and move the stud so you are pulling the short cable.
Try this and retest in water under load.
Anyway there are tests that would tell you if the cable is bad but to difficult to type out here but in general if you remove the shift control cable from the shift bracket, shift the control handle to full forward/wide open throttle and make a mark on the cable end, now go full reverse and repeat. Measure distance between marks, (2 7/8" to 3 1/8") any more and replace the control cable.
Short cable measurement test, remove short cable from shift bracket, push all the way in and spin prop by hand until full forward is made. Make a mark on shift cable end where the plastic stops over the metal.
Now with someone holding the prop from spinning pull the cable end out with two fingers, as soon as resistance is felt mark the inner cable where the plastic cable end ends. Now measure between the marks,
The measurement should beif I remember correctly 1/2 " to 9/16". anymore and the cable or linkage is bad.
