I have a 83' Johnson Seahorse 7.5 (Model:J8RCTA SN:E5742836) that has a "popping out of gear" issue. When I disassembled the lower end, I noticed the two needle bearings that support the drive shaft appear to be missing a needle or two. The needles themselves have a tapered point on each end that slides into a channel on the bearing housing itself. I'm guessing this is to keep the needles from slipping out. The only way to get the needle into the housing itself is to install it diagonally and then straighten once inside the housing. For the inexperienced person(myself), this vacant space seems necessary for seating of the needles. Am I missing a needle or two or is this by design? Thanks for any input...........Mark
