Took the "old gal" out this morning for a little fishing trip. For some reason the battery doesn't seem to be taking a charge. The battery is a new 1000 cold crank amp, deep cycle marine battery. My on board volt meter says 13.5 volts when traveling around the bay. When moored the only thing on is my Lawrence HDS-7 sonar. After few minutes the sonar beeps and says low voltage and cranking power is weak but does start. Belt is tight. Any ideas? Don't have an amp meter to test charging amps.
