Aggieben04
I changed the impeller last week and in order to get the housing off, I had to take the belt off the water pump and pull the water pump. Now that I have the impeller put back together on the water pump, I can't get the belt back on over the water pump. I've tried adjusting the water pump over but it won't go far enough. There's no other means to relieve tension on the belt that I know of but then again I'm an ameteur mechanic. Any help would be appreciated so I don't have to pull it into the dealership to have them finish what should be a simple job. Thanks.
