81 Merc 200 20 HP
Check to see if it is running on both cylinders.-----------------They will run on one !--------Check compression and check for STRONG spark.
Has a very strong spark was not running on bottom cyl put a different plug made some difference, great compression 120+ could run better may be it could it be timing? thanks
Timing on outboards generally is " bang on " unless tampered with.---------------------Maybe the bottom reeds have a problem ??----------Maybe the lower crankshaft seal is defective.--------Is the boost venturi in place ??
