rosbullterrier
"I read these should be change
"I read these should be changed every 2-3 years and my boats been laid up for about 10 years . .
Well, the swivel housings came off fairly easily, then four large bolts undone and the impeller housing tapped out. The top bevel gear has then to be hammered out.
But the central shaft is still held in place by the lower roller bearing. To remove the impeller housing it seems this must be removed. I dismantled both outdrives to prove that just one wasn't stuck, but no, both shafts appear to need pressing through that lower bearing.
It seems a difficult process to replace a pump impeller - or is the design to prevent them without the equipment?"
