1980 merc 9.8hp. Manual start.
So i decided to tighten up my throttle cables this past weekend. I also adjusted the screws for the throttle plate, so now the plate closes tighter down and is more closer to 180 degrees on wot.
So i set off this morning to go bed fishing and it took the outboard 3-6 pulls to start it up, compared to before my adjustments when it took pnly 1-2 pulls. When its up and running there are no noticeable problems when idling or at wot. Starts back up in 1 pull if outboard is still warm. If its cold, yes it takes 3-6 pulls.
Carb is clean, spark is good, compression is good. I am guessing that i might have messed up the ignition timing with the adjustments that ive made.
Anybody have a way for me to check this? Any other odeas are welcome and much appreciated
