80 hp evinrude starflite
paulc123
"I have just purchased an 1968
"I have just purchased an 1968 alpex with an evinrude starflite 80 hp... model # 80683c.. the engine looks to be in great shape and i am told that it ran great when taken out of water.. But i have no spark.. Replaced coil, checked the points and everything seems to be in good shape..also i just ordered a service and parts manual for motor.. Anyone with any info or help would be much appreciated??"
"That's a 1966 80hp Evinru
"That's a 1966 80hp Evinrude. I assume that it has automotive ignition. If you have voltage going to the coil, and the points are clean and set on the high lobe so that a .020 gauge passes thru but a .022 does not..... I would suspect a shorted rotor arcing out to the metal shaft upon which it sits.
Note that there are two different type rotors.
The automotive type rotor simply has a normal s squared off end.... 580338
The magneto type rotor has a weird looking end, sort of shaped like a crude hook.... 580260"
"Thanks guys.. it is the autom
"Thanks guys.. it is the automotive type and i will check the voltage to the coil, im just too excited to get this baby up and running, i just gotta slow down and take my time... If you guys have any links or any other info on this motor that would be awesome thanks..."
"I have just purchased an 1968 alpex with an evinrude starflite 80 hp... model # 80683c.. the engine looks to be in great shape and i am told that it ran great when taken out of water.. But i have no spark.. Replaced coil, checked the points and everything seems to be in good shape..also i just ordered a service and parts manual for motor.. Anyone with any info or help would be much appreciated??" Still have this boat, I have one im rebuilding would love some pics [email protected]
