Hi!,
Took off the carb and took it apart to clean. The float pin(holds it on) has a spring the pin goes through. I tried to look at it before I removed pin and the pin slid out before I could see how the spring was put on. When I put it back together the float had tension on it holding it open. Is this correct ? Thanks for any help. This motor is Mod#K751, KTV 50576A, ser#1605897. Also is 50:1 fuel mix correct. Using 2 cycle air cooled oil.?
John
John
