Perhaps someone can explain the purpose of the wing plates used between the manifold and riser, and riser to elbow on the 8.1L Crusader engines with heated risers. The diagram I have seen shows a pass-thru stainless steel wing plate sandwiched between two gaskets. Since the riser and manifold are within the closed coolant/antifreeze section of the exhaust system, what function does the wing plate serve? I can see using the block-off wing plate between the riser and elbow to separate the raw water form the anti-freeze, but why not just use a single gasket between the manifold and riser?
