Crusader 8.1 MPI 496 appears to search or pulsate between 1000 & 1400 rpms. Lower and higher rpms OK, and idle speed OK. Seems to disappear for the most part with a load on, (i.e. underway).
Second issue: port tachometer upon initial startup needle slowly clocks to full scale high and stays there. Shut engine down and restart works fine. Hour digits disappear. 308 total time on engines 2005 vintage engines.
Appreciate your thoughts on these questions.
Thanks.
Thanks.
