I have a 8.0 KW Westerbeke gen that the fuel pump will not activate and prime accordingly therefore causing the engine not to start. I have replaced both relays and the Start Stop switch but niether has helped. The reading is less than 1 volt at the pump however, I am able to jump power to the pump and it work.
Any ideas on what is causing the low to no volts at the fuel pump?
