Overall this motor is running great with cooling problems resolved and a new fuel pump. The one small issue I'm still having is it's hard to start, even when warm. When the engine is cold I prime the bulb until completely firm, give it choke, put the throttle to START, and then it takes several pulls to get it to fire. Again, once running it goes like a champ. When the engine is warm it takes several pulls to get it to start. Sometimes I have to give it about 1/2 choke and wait for it to fire, sputter, and die. Once it does that I can disengage the choke and it will start. At no point can I put the throttle to START and have it fire on the 1st or 2nd pull.
Compression is 90PSI and dead even on both cylinders.
Spark is bright blue and jumps 7/16" gap on both.
When I had my last issue I punted and took it to a shop. They found the fuel pump was shot and installed a new one to get it running well. At that time they said the carburetor was fine and didn't need any work.
This is sounding like a fuel delivery issue to me and I think I may need to run through the carburetor after all. I'm wondering if there is some kind of debris in the low speed fuel circuit that is causing the hard start issue. But, I'll gladly take any advice on where to look first so I'm not chasing rabbits down holes.
Thanks guys.
Kevin
Thanks guys.
Kevin
