I’ve recently bought a used 35h motor. It’s had not been ran in what looked like quite some time. Unfortunately I do not have any history on the motor.
It was in shambles when I purchased it. But having a boat without a motor wasn’t doing me any good. And finding a motor I could afford was unexpected. I suspect when whoever owned it prior had it apart they couldn’t figure out how it went back together so just slapped it together and threw it in a shed.
Lower unit was missing detent balls and spring and all thrust washers. Now that I have the lower unit back together I’m finding issues I’m not familiar with. I have little motor experience and I’m learning as I go.
But the motor is returning over 16v to the battery when throttle is opened up (with cups on). Also the starter seems to want to engage while throttle is opened up and jumps up and smacks the flywheel. And then there is the arcing. You can see electrical discharges where the control lever connects to the throttle control rod linkage. I’m completely lost.
