Hi,
I just bought a 79 Trojan F32 w/ twin LM318B's and Carter AFB's. I've been reading some threads regarding carbs, distributors, etc. I am having an issue with the starboard engine. Starts ok (with a little throttle coaxing) and runs ok. It will backfire (not too often) after running a while around 2800 RPM and seems to bog down a bit. Sometimes I can back the throttle down a touch and it runs a little smoother. If I try to run at idle (trolling) the starboard engine dies. It starts right back up but won't stay running at low speed the rest of the day even after leaving it off for a couple hours. I changed the fuel filter. It looked pretty clean and fuel was clean. Any suggestions on where to start? I'm thinking from what I read here that I may want to start with ignition. Should I try Jeff's "30 Min distributor workout" or does that apply to my electronic ignition? BTW-My engines seem to be idling high-800 RPM. Any help would be greatly appreciated.
