" I got 4000 rpm's WOT. My
" I got 4000 rpm's WOT. My engine is running lean I'm fairly certain, because it won't idle unless I bump the choke, I bumped the choke at WOT and the rpm's increased by 100. I'm just doing a little research as far as my prop is concerned in case I don't achieve 5000 rpm's after I straighten out my carburetor problem. Right now I'm running a 3 blade, 12-1/4x15 prop. Is there a formula or rule of thumb method to determine the correct prop?
Also, could I get some feedback on the Comprop line of props? (4-blade composite) "
