78 Johnson 140 idle jet size
ship wreck
I'm cleaning the carbs of the 140 in my sig and noticed the idle jets are different from side to side. Both carbs are the same with a #34 in one side an a #31 in the other. Looking at the diagrams here tells me I need only one idle jet for a 140, which has to be a mistake, but at that it says a #30. I see from another source that a 78 115 has a different idle jets side to side so I'm wondering if that is the case with the 140. The body of the carb has printing on it that says use #25 on one side and #27 on the other which means I'd put an 85 HP jet on one side and a 115 Port jet on the other. I found the cast in part number on the carb body crosses to a 140 carb so I'm thoroughly confused.
I know the jets have been monkeyed with as the #31 jets were buggered up from an attempt to remove them and I had to dress them around the screwdriver slot. This may have been during a cleaning attempt and not an attempt to change them but a lot can happen in 36 years
I've not had the motor on the water yet I've only run it on a stand where it ran OK but I was hoping that was just junk in the carbs. Now I'm wondering if I have bigger issues and I'd like to get the jetting resolved before putting the carbs back on.
So the question is; what is the stock jetting for idle and what does the main jet size cross to in decimal? I'm concerned the main jets are wrong but I can't see any numbering on them, and I've not measured them yet, but I don't want to drop 40 bucks in jets for no reason.
I measured the main jets and they measure out at .067 with my drill gauges. They could be off a bit as they are not very high quality so I assume a 65c main jet (what is called for in the parts breakdown here) is .065 and that would track with what I measured given that is only a 3% difference.
