78 Evinrude VRO fuel problem
my4x4awd
"1978 Evinrude 70Hp VRO. I re
"1978 Evinrude 70Hp VRO. I rebuilt this engine 6 months ago along with new gas tanks, VRO pump and new oil tank and warning horn. Engine has run great every time since rebuild until Saturday. It is having a fuel problem I can’t figure out. After 1-2 minutes at full throttle. (I don’t know rpm because I can’t find a tach for it) engine will slow to a stop and die. No missing or popping. I have two tanks and checked the obvious, no water in gas, hard bulb and I use fuel stabilizer year round. If I keep squeezing the bulb it will run or if I slow down to half throttle it will run. I also cleaned carbs and the fuel filters and purged the fuel system. I have the carbs with the fixed high and low speed jets, no screws to adjust. The only thing that has changed is the connector on the fuel hose tank side. It was used and don’t remember before or after trouble started. I’m going to buy a new one today. Would a bad connector cause this? Can someone help out?"
I thought VRO did not come out
I thought VRO did not come out till 84 or so. So what is the model #
I had same problem on my ficht
I had same problem on my ficht. Was the lift pump for the fuel. The alchohol in thr gas ate the rubber valves up inside. New rebuild kit came with nylon valves. I'm sure the fuel pump on ur motor is the same.
"a bad/leaking fuel conn could
"a bad/leaking fuel conn could cause your problem..sounds more like a bad fuel pump,or clogged filter."
