E
Earnest Finney
Guest
I have 1978 115hp Evinrude wi
I have 1978 115hp Evinrude with a running problem. The motor starts and idles fine and has no hesitation. After about 15 minutes its starts to die. The primer bulb is new and the fuel is clean. When it does it the primer bulb is collapsed to where I can't pump it. To make it run normal I have to momentarily disconnect the fuel line from the tank. Thanks for your help.
