oldschoolnc
Hello. Is there a way to bench test the trigger? and is a special tool required to install the plug wire terminal end that screws into the dist. cap? Thanks for your time.
A ohm meter test will tell you all you know to know. It's a simple circuit of magnetic pickups.
Heres the Answer...Any more questions?
I use a coax crimping tool as it form a 6 side hex....is a special tool required to install the plug wire terminal end that screws into the dist. cap?
