"Guys, tried everything?..
Mo
Motor was perfect for 2 years use...
Symptom is.. Starts and idles a treat, runs clean at half throttle in 5 min test.
Give it full throttle and it runs clean for 20 seconds then dies.. dead, starts with 3 pulls and goes at full throttle for another 20 seconds.(not missing or spluttering - clean death)
checked line and tank, tried with cap loose, no leaks in lines, tried bypassing bulb, stripped and cleaned carb -looked fine anyway, bulb looks fine, seat ok and not leaking, filter clean,tried a loaner pump (although was from a 9.9hp johnson) but did exactly the same.
Emptied tank/new fuel/mix..
How can I test/verify what the cause is?
I'm sure it's fuel, not electrical.. just feels fuelish (if that's a word).. annoying cause I can only test it in the water under load which means.. you guessed it - whinging kids. Would like to fix myself so any tricks in how I can narrow down the culprit would be appreciated.
thanks
AJ"
Mo
thanks
AJ"
