oldsoldier
Bought 2 HP from guy who hadn't run engine for "a while". Said it would only run when sprayed with ether
. So I thought the carb needed rebuild. Wheb I took it aprt, it was just a little dirty but has very little adjustment on low idle speed needle valve.
Question: low speed neddle valve - should needle seat in the small hole at the end of the chamber like the high speed? Mine does not. Threads (1/4-28) on needle valve or in chamber (one or the other)stop needle from end of chamber by 3/8". Do I need to tap the threads deeper in the chambre or did someone use the wrong needle valve?
