SRLEONARD88
So I made post earlier about time-base fitment issues. I got that all sorted out and all my "electrical" issues sorted. The issue I'm having now is little to no vacuum through carbs 2-3. Compression 120 115 115. Lync and sync has been done and checked over multiple times. Reed valves are good from hat I can tell I've removed them totally inspected and replaced with new gaskets (light film of gasket sealer on gaskets). The issue is consistent even with carbs removed and both from the plug side and carb side. I did remove the c shaped "plastics" directly below the power head to get a better look at the exhaust housing and there seems to be oil on the bottom of the exhaust housing. Any help would be greatly appreciated.
