ship wreck
I'm having issues with this motor idling in the water. IT idles fine on the muffs but does not want to stay running while in the water. I've been doing a lot of troubleshooting and today I was checking for vacuum leaks with carb cleaner. For good measure I shot a bit down the carbs and on the bottom carb it caused the motor to speed up not slow like it di in the other two carbs. Ok so that carb is lean. It's not dead as because when I pull the plug the engine does change pitch and speed so it is fueling a bit but not enough. To verify I unhooked the chokes so I cold close them individually. On the top and middle carb closing the choke kills the motor. On the bottom carb it causes the motor to smoke a bit but it stays running no matter how long I hold it closed.
I just rebuilt these carbs in the last month which cured my problem of the motor dying when transitioning from idle. The floats, needle and seat were replaced and set per the instructions in the carb kit. I'm not sure what could have happened here but my main concern is knowing won't have the same issue if I go through the carb again. Not much to these carbs and when I "rebuilt" them I did pull all the plugs sprayed out all the passages, blew them out with air and inspected all the passages to make sure they were clear.
Any advise on bench testing or is there something specific to look out for?
