HELLO.
My 1977 25HP manual start w/CDII ignition has been increasingly difficult to start until last week when it totally refused. After checking the obvious I found no spark. I used my multimeter to perform the first 8 tests per Seloc but I do not have M8 or S8 tester to proceed. On advice of a backyard mechanic I used my meter and found the charge coil generating 30 to 35V and the sensor 0.2 to o.25V. Is this sufficient and if so how do I check the power pack or do I assume it is bad and put in new?
5 Yrs ago I had similar problem (although it would start eventually] and I replaced 2 ignition coils, power coil, sensor coil and then the power pack as I still had no spark. Worked exceedingly well till recently. Both ignition coil covers were cracked then but the replacements are in spec. per Seloc tests. The engine is old and pistons scored but I have 100 compression and am trying to keep costs down so if I need it I will have some cash for a new engine. HELP
