W
wade
Guest
"motor would every now and the
"motor would every now and then either not start or start and run a few minutes and then dye and it would take alot of cranking and then might start again and stay running but would run rough.Rebult carb,replaced points and condensers,has two new coils.After doing all this it started and ran at idle for a few minutes and then when put in gear and tried to to accelerate it died and would never start again.Took flywheel back off and rechecked everything looked ok and it still woulnt start?I have spark and 130 psi on each cylinder for comp.Even tried a fuel pump and carb off a motor that does run and didnt help.I set points at 20 with rubbing block at keyway on crank.If driver coil was bad would i have no spark at all?I did have driv. coil off and lined it up with boss on arm. plate?I have fuel on plugs and even tried a different fuel tank!I also have tried plugs out of a running engine that is identical to mine!Can it be vacum related?Any help would be appricated!Thank you"
