Matthew Ritchie
Before I get started, I'll give you some info on the the outboard and it's problem. It is a 1976 35HP Evinrude Model #: 35652S. I took a gamble when I purchased it, but for $75 who wouldn't. It wasn't running and one of the starter mounting holes (the one directly above the carborator) on the crankcase was cracked off and stripped out. Well, I got it running, after replacing a few parts (coil packs, plugs, low speed needle and some wires) by pushing against the stater. I don't know what I was thinking but I turned the key without pushing against the starter (only 2 of the 3 bolts holding it in place) and BAM. I tore the other 2 stater mounting bolts/threads on the crankcase. I've searched for a replacement crankcase ensemble for 1976 and nothing. Not even used. I know they are different part numbers, but can i go up a few years (77-81) and use one of their crankcases? All the diagrams show them being the same, but the part numbers do differ. I'm probably wrong. Hope I'm not though. Found a few 78's and a 81 crankcase on ebay. Thank you.
